Power Steering doesnt work
rboyer87
I recently bought a 95 bayliner capri 2050 and the power steering does not work. Its my first boat and the only thing i know to change would be the power steering pump. Before i spend 300 dollars on a pump is there something else i should try first? Thanks.
Re: Power Steering doesnt work
Ayuh,... Welcome Aboard,...
Pull the cable from the aluminum tube at the transom, 'n clean the corrosion outa it...
Then grease, 'n reassemble...
TilliamWe
Banned
And if you do end up needing a power steering pump, don't spend $300 on it! They are the exact same pumps as on GM trucks. Just switch the reservoir.
