Engine runs great but overheats quickly and dip stick has white milky looking oil.
1976 Grew, 6 cyl 165 hp I/O.
Got shafted buying a bought with a problem.
Can anyone help me understand what is happening here?
I really appreciate it.
The engine starts and the bought drives but overheats fast and dip stick is mikly.
Thanks.
Re: Engine runs great but overheats quickly and dip stick has white milky looking oil
Thanks.
Ayuh,... My guess is, the impeller in the drive is Shot, 'n the motor's got a Cracked block....
Is there water running into the bilge when yer boatin',..??
stackz
Master Chief Petty Officer
that or a headgasket. pull the plugs and look for one or two that are spanking clean compared to the rest...means they are burning water in the cylinder.
Not sure. Where would I look for that? If you are correct how much money am I looking at approximately to have it fixed?
I am hoping its a head gasket correct? Less costly than a block?
