Evinrude 6hp 2 stroke outboard motor model # E6RCEC... Looking for an owners manual
dukester544600
Hi as stated above I am looking for an owner?s manual for an evinrude 6 hp motor. It's model # E6RCEC. It belongs to my grandfather and I am trying to find out the correct oil/fuel mixture and things of that nature. I have done a lot of online searching but all I can seem to find is parts diagrams. If anyone can point in the direction of where I can find a manual online that would be very helpful. Alternatively if someone can give me the oil/fuel mixture this engine uses that would be very helpful as a start. Thanks for any help you can provide.
Xcusme
Re: Evinrude 6hp 2 stroke outboard motor model # E6RCEC... Looking for an owners manu
It looks like you have a 1989 model.....therefore it would be 50:1 on the gas/oil mix.
dukester544600
Thanks for the reply but I figured since it was an older engine it would be online somewhere. They want $40 for it on the website you advised. Thanks for the oil/gas mixture though. I was pretty when I was a kid thats what we mixed it to but it's been over 10 years since I have used this engine so I thought I would check and see.
wilde1j
Almost all 2s from the mid 60's on use 50:1. You might try outboardbooks.com for the owner's manual or Fleabay. There are generally no free on line document sources for most outboards.
dukester544600
Is it better to use fuel without any ethanol in this engine?
wilde1j
Sure, if you can get it easily.
dukester544600
Well I can buy it from the gas station as easy as fuel with ethanol but I have heard several people saying that these types of small engines are not designed to run on fuel that is blended with ethanol so I thought I would ask and see if anyone knew.
wilde1j
Unless you have an antique engine, ethanol isn't a major problem. The alarm over ethanol is way overblown. It's is a crappy fuel though.
JB
They weren't "designed to" run on gas with lead in it either, Dukester. I don't understand why nobody went into cardiac arrest over that.
