Hi everyone,
I have read alot of forums on Iboats and learned alot of information about my boat
First I would like to say it is awesome here and am looking forward to the wealth of knowledge this site and its members seem to have!!!
So hello everyone!!
My question is I have been scratching my head with the problem I am having, I am looking for any help that anyone with some know how can help maybe
I have a mercury outboard 2 cyl. 25 hp 1980 to 1990 electric start outboard
I bought it last year in B.C from a nice fellow and well maintained boat for being in salt water
the first couple days the boat started well with the electric key start. then the starter or solenoid died. we had to pull start for the rest of our fishing trip.
when I got back I went and had the starter rebuilt, came home installed cleaned all the terminals checked voltage and everything was good installed the starter and when I turned the key I got one crank from the motor/starter and then just the click sound from the solenoid. Took starter back of course and it was fried again so warranty covered and fixed again. Scared to install starter I waited until this month to install and boom it happens again. The company that I had rebuilt from had been bought out so I purchased a new starter. I this time put a inline fuse from main line on battery, installed starter and again got one start and boom fuse blew, man was I glad I didnt kill the brand new 230 starter. I have voltage tested all the lines on solenoid, I get 12 volts on right side and when the key is turned I have 12 volts on starter side. key off no voltage key on voltage. checked the grounds and they all look right. everytime i turn key i get one crank and pop fuse blows. I have taken the ignition apart as well and it all looks good. I have been on this for 7 hrs now and cant seem to fix it I am leaving for cod fishing on friday and I cant get the starter to work. The starter works fine when I hook to just the battery. If I use the line on solenoid and ground to battery it blows the fuse. please any help from some pros would be great.
This is a weird one. I have good experience with DC wiring from alarm and car stereo installations, this has me beat literally,
The one thing that I wonder about is on the right side of solenoid there are 2 wires, one main from battery and a smaller one from the ignition, when I use my volt meter on the smaller wire I get voltage but only voltage as a ground when key is on. I put the red from volt meter on battery and turn key to on and put the black to the little red wire disconnected from solenoid and I get voltage on the meter. what is this little red wire and what does it do. when It is connected it makes the switch in the solenoid power the other side to starter. when it is disconnected it has no power on left side of solenoid.
sorry this is so long wanted to be exact so to make it easy for a pro to help out.
anyway awesome site love it, can oyu buy parts from here as well?? I might think to change the solenoid as well
THANK YOU FOR LETTING ME BE A PART OF THIS!!!!
Gordo
So hello everyone!!
Gordo
