chefnatewilson
- May 28, 2011
- 8
I have a 25 horse 1992 Evinrude model E25ELENS . I am having a problem when I get to WOT it surges I back it off for 2 or 3 min open it back up to WOT then everything works fine . I noticed my bulb was a bit squishy so I purchesed a new one thinking the check valve may be leaking . This did not fix the problem I figure I must have a air leak or somthing of that nature . could it be the fuel pump needs replaced or do I have somthing else going on . Like I said when I back off and then hang a bit before I go WOT everything is fine . What do you guys think have you seen this before or has it happened thanks guys for the help
