Nutron
- Jul 10, 2011
- 73
I have a 1975 Johnson 115hp motor. When we run down the river to the place we are stopping the engine runs great, I throw it into neutral and it idols just fine. The question is when the motor is shut of for a while, while the kids are swimming I go to start up and move on and every time you have to pull the cover off and choke it with the manuel choke setting on the side of the carb, I use the auto choke on the key and it does not want to start at all. When you manually use the choke setting it kicks over and then you click it to normal and it will start right up. How do I go about correcting this problem? Any suggestions would be great. Thanks for the help.
