I have a 93 200 ocean runner that i am having an issue with fuel delivery. If you prime the bulb, motor starts and idles fine but after about a minute (or running the fuel out of the carbs) the motor begins to die unless you pump the bulb. Then the motor will run again. So far i have:
1. Cleaned Carbs
2. Replaced Primer Bulb
3. Replaced fuel lines and hose clamps
4. Lastly, I put a vacuum/pressure tester both before the fuel pump and after the fuel pump with the same result. I can pump it to 4-5 psi, but when the motor runs it drops to nothing.
To me it sounds as if the VRO pump has gone bad, but before i replace or repair, does anyone know of anything else i could to to test the pump? And should i repair with max kit or replace whole unit?
Thanks in advance for your help!
1. Cleaned Carbs
