when turning hard right the motor makes a grinding sound. Starting to do it when you turn left as well. From reading posts on here I thought that it would be the U joints. But when I got to them they look okay. The shaft that is attached to the U joints that goes through to the engine has play in it. So I am thinking bearings. What I am wondering is how to get at them. I loosened the six hexagon bolts that are attached to the flywheel housing (I think that is what it is called) and was going to pull the entire unit out. But thought that I should get a second opinion. I am going to the library to see if they have a manual. Might help
