I picked up my first boat the other day and have been relatively happy with it so im now onto fixing its issues which is mainly the electrical. My first order of businees is to get the key to actually start the motor. The po used a length of wire going from the started terminal and touched it against the battery to start the motor. Its now my job to fix it but the motor has been touched by a hacker. Im getting 12.6v at on of the smaller terminals when the key is turned but not anywere else. Im thinking its either the soleniod, the safety switch of possible the fuse. My problem is figuring out which it is. Currently the engine only has one fusable link in the red harness with the oem twist connector but i did find another partially hooked up on the wire block that had been just floating around for god knows how long. It too is a red wire but maybe looks like a add-on but it has the same oem style twist fuse connector. Is this engine only supposed to have 1 link or am i missing one and that could be my problem? Im hoping its the soleniod since its cheap but i wanna rule everything else out first.
