hey guys- how are you all doing today??? I am having a hard time getting my stern to stop leaking oil out the weeping hole. When I had the lower unit of i had it pressure tested and it was tight, the top unit wouldn't hold a vacuum, so I am sure its in the upper unit?? Last summer I did a water impeller change and ever since then, I have had oil leaking from my weeping hole. If I fill both units and then fill my reserve bottle on the inside transom, there is oil leaking, but if I remove the reserve bottle and empty it out, the oil stops leaking after a few minutes.
Can any of you guys help me with some advice??? Thank you very much.....cal
