G
Guest
Guest
I got my 1975 evinrude completely put back together after buying it for 75 bucks and finding out the crankshaft was broken. I got a used powerhead from a really nice guy in florida. Its all put back together, not one extra bolt or part. I changed the lower unit oil, rebuilt the carb reset the points and new spark plugs. The problem I'm having though is when I'm trying to pull start it, its pretty tough to pull and seems as if I can only get the flywheel to turn over once or twice because of the resistance. The flywheel and engine turn over relatively easy by its self, as does the recoil starter. But when used together its much harder. Any ideas? It wouldn't have anything to do with the powerhead sitting for a while and maybe since there hasn't been any fuel ran through it to lubricate the cylinders? That's just a rookie guess. Any help or ideas would be great!
