Re: Removing Concrete from hull
What are all of these acid solutions going to do to the trailer the boat is sitting on, what about the carpet on the bunks?
Concrete is mostly lime, not calcium.
I would suggest a powerful pressure washer (3000 psi) with a turbo tip on the sprayer wand. Test on an inconspicious spot on the boat first. Start at a distance of about 3' to make sure you aren't hurting anything and move closer until you get a good cleaning action.
If you try everything and nothing works, you'll have to very carefully pick the concrete off with a metal putty knife.
In the concrete construction trade we use pressure washers, sharp scrapers, hammers, and chipping/jack hammers to remove concrete that has setup... it doesn't come off easy.
The pressure washer and acid solutions work best on concrete and mortar that hasn't setup completely. I don't think this is your case.
