motorguide trolling motor
snowmann
I have an older motorguide lazer 320RF trolling motor with a problem. Evergthing seems to work fine exept it seems to be stuck in fast mode. The speed controls don't respond. Any thoughts?
bpalmer
Re: motorguide trolling motor
I just bought a used boat with an older (year ?) motorguide 320es Lazer trolling motor on it. When I bought the boat the previous owner showed me how it worked. It turned on fine but would not turn left or right. There was only a clicking noise when pressing the right button. I took the cover off and there was a lot of moisture in there. I just hooked it to the battery and checked all of the connections but now it will only click when pressing the right button. It won't turn off or do anything else. Sorry I don't have an answer but now but I am going to work on it over the next day or so and try to figure it out. I will keep checking back and maybe someone can answer it for both of us or I will figure it out and let you know. Good Luck!
