Nathan Hamilton
- Aug 28, 2010
- 7
My motor (1972 50 hp) starts and runs properly. However, it does not turn off when I turn the key to the "off" position. It continues to run until I remove its fuel supply and runs out of gas.
I was told that the blocking diode was likely the problem, so I replaced it. This has made no difference.
It might be necessary to note that I use the technique discussed in this forum, http://forums.iboats.com/showthread.php?t=175907, to bypass the original shift switch in the remote control using a toggle switch.
