Re: get gas tank out of a 1986 bayliner center console trophy
I have a 1984 Trophy center console and if its the same set up you would have to split the deck off the boat to get the gas tank out - All i did to clean it out was take out the fuel sending unit- raise the front of the boat as high as i could - pump out the old gas - sprayed carb cleaner into the tank and sucked that out. Put in a a fuel sending unit - lowered the boat and filled it up. Good time to run a new fuel line to the engine while down there. The one thing i didnt do while in the tank was to check and clean the fuel pick up - so now 2 years later i have to go back and do that due to a runability issue i am having. Have a look at that aswell to save time in the future.
Cheers
Griffin
