sx-m drive, need to rev to go fwd
tayznild
when i put the control in forward it doesnt engage until i rev the engine. any idea the problem is? the cable is good condition.
saintlee
Re: sx-m drive, need to rev to go fwd
maybe 1 a spun prop
2 check fluid level of drive
3 check cable adjustment at both ends
4 shift linkage at drive
once moving does it ride normal?
happen in reverse also?
JordanFTW
Go out back and check to make sure the cable is fully engaging the drive. Take the 3 10mm bolts off the upper cover of the drive to access. It sounds like you are not fully engaging it and you cable probably needs adjustment.
tayznild
after looking insidethe drive, notice that the clutch sleeve slips alot before it engage.
can i mod the clutch so it engage better?
Don S
Nope,
Is the shift cable actually pushing the shift mechanism all the way into gear?
With the engine running, move the shifter into gear and see if the shift mechanism will turn any further by hand.
tayznild
the clutch slips in fwd and not in rwd. i will try to mod the clutch so i can use it for a few month more. i think i can grind the tip of it so the clutch can go deeper.
tayznild
does the clutch engage in it sides or in its tips? any help apreciated.
