Hi'
can I swap flywheels from a Big twin 35 sn# 25029-11326 to a 25 hp sn# 25916-1193 they both look the same the flywheel on the 25 seems to be bent/warped. also could I get what year they are
thanks' I/A
Should have the 6 digit part number stamped on 'em. If they're the same, no problem. If not, I don't know if it'd work or not. I'd measure 'em and check magnet placement and if it checks out, give it a go.
