1973 Mercruiser 1 - 165 gimbal ring removal
Status
Not open for further replies.
muleguitar
Currently removing the gimbal ring to get to the limit switch. I've got the lower shaft removed, as well as the bell housing and belows. The upper shaft is giving me a problem. It is splined, and has an allan plug that i removed from bottom, and removed the allan bolt that goes through the side of the upper gimbal ring and through the upper shaft. Where do i go from here? Do i have to remove the steering arm from the gimbal ring somehow to get the shaft to fall out?
Re: 1973 Mercruiser 1 - 165 gimbal ring removal
Ayuh,... The tiller arm is bolted to the other end of the shaft...
Pete104
Do you have a new limit switch?
muleguitar
Do you have a new limit switch?[/QUOTE
I don't have a new limit switch. I can see that the wires are corroded up to the limit switch and i'd like to get to it first to determine what to do.
Status
