Re: 9.5 runs weak, then dies
First things first. 1, did you check compression? What are the #s? 2nd, Have you checked spark with spark tester? 3rd, When was the last time carb was overhauled? If it has been more than a year, Overhaul carb with new carb kit. Check the first 3 things and post yer results!
