My 79 cobalt that has been out of the water for a number of years. See my signature for a few before pics..
The boat is an hour south at my mothers, I visit each weekend and been putting in some hott and humid hours to get her ready for the water...We are planning to take her out this weekend. First time it's ever been in the water for us, and the first time in atleast 4-5 years for the boat.
I've changed all the fluids, plugs, etc. Replaced the carb. Installed an aftermarket temp gauge even though the factory one was moving and showed 'ok', just wanted reassurance. She isn't perfect, but I ran her on the muffs for 20+ minutes and the temp gauge never got above 130ish.
I haven't pulled the upper part of the out drive to check the gimbal, from what I've read this is quite a job and you 'might as well' replace quite a few $$ parts while in there. I have no problems doing this, and not trying to skate on the job. I just want a bit of reassurance I have a boat worth fixing, before I start fixing it. Not planning a 10 hour day pulling tubes/skis, just a she floats. She drives, she doesn't spontaneously combust trial run before spending more money.
Things i've done:
cleaned the boat(it was a mess)
replaced plugs/fluids/points/belts
checked that it goes into drive, neutral, reverse
checked the trim goes up/down.
pulled the lower drive and replaced the water pump impeller. The old one looked brand new(Which makes me feel the PO had done maint on the boat..) replaced gear oil
ran it on muffs quite a bit, not had any issues.
Goes into forward, reverse, neutral on muffs without issue.
steering turns without issue.
TBH after reading some stories, i'm worried what'll happen on the water. People's good boats, that have been known to work not going over 10mph. taking on water, spinning prop hubs, over revving, sinking, etc.. Who knows what will happen with mine.
Here's my 'plan' for this weekend.
Friday evening take it to the lake when it should be pretty dead, hopefully an empty launch area. Float the boat on the trailer. Start the boat. Let it run for a while(20 minutes?), while still connected but floating.
Kill boat, pull out of water. Check to see how much water, if any, is in the bilge, give everything a once over.
Put back in water, crank again. Take off trailer.
float around the marina for a bit.
Either put back on trailer again, or take it for a small 'cruise' to make sure she'll plane.
Put back on trailer, check for leaks etc.
I figure this all take an hour or two. If at the end she is still floating, not over heated, is able to plane, goes into gear, and hasn't taken any(or much) water on.. I should be 'ok' ? Any other things to do once I get her on the lake for the first time in 5 years?
I'd like to do the above Friday evening, and if all checks out, take the family out on it Saturday for a light day. Not cruising at full throttle or pulling skis, just mainly get on the lake and enjoy the water.
running last weekend..
http://www.youtube.com/watch?v=wRVz-brQivg&feature=youtube_gdata_player
thanks for all the input on this forum, been a valuable source while working on this boat. I've never done this much prep before taking a boat out. Growing up on a pawn shop, if I could get the boat running.. I took it out. Ignorantly blissful of the huge amount of things that could of went wrong and caused serious issues.. guess I always got lucky!
Things i've done:
