I have a 1981 Ranger 320-V Comanche with a livewell. The livewell drain has been adapted with a metal drain connector - it appears to be a standard "plumbing adaptor/connector" - it looks "similar" to the attached photo. I assume another fiitting is attached to this and extends through the livewell. A drain hose is then connected between this other fitting and the drain hole in the transom.
However, the drain plug in the livewell does not make a complete seal inside this metal connector. I want to replace the livewell drain with a better solution.
What do I look for? Would I use a thru-hull connector of the same diameter as the current drain?
Thanks for any advice.
