Deryl Sellmeyer
- Jul 26, 2011
- 4
I have a 2000 model Bayliner Capri, with a 135 h.p. 4cylinder GM engine and a Mercruiser Alpha One stern drive. My problem is that I yanked back a bit hard on the control to put it in reverse as I was coming into a dock, and then I could not get it out of reverse without killing the engine. Now I can shift into drive, but I have trouble getting it into neutral when its running. Also, I still can't get it back into neutral when it is in reverse and running. The boat is 2 1/2 hours away so I need to have an idea of what I should do when I get to the lake to work on it.
Let me know if I'm thinking right, because when I talk to repair shops they're guess is that the shift cable needs to be replaced for $400 to $500 with parts and labor. Here is what I've done to analyze the problem:
1.) I disconnected the shift cable at the shift plate mounted on the engine. I found that when the cable is pushed in the propeller will lock into gear counter clockwise. When the cable is only pulled halfway out the prop spins freely. When the shift cable is pulled all the way the prop will lock into place going clockwise. This makes me think the shift cable is not the problem.
2.) I checked to see if the shift interruptor switch is working by pressing the plunger pin in with a screw driver. This killed the engine as it should.
3.) I'm reading a Mercruiser manual and coming up with the idea that I probably need to disconnect the cable that goes to the control at the shift plate on the engine, and try to adjust the cable. Am I on the right track, or should I be towing this boat to the marina for an expensive repair?
