- Jul 7, 2010
- 15,109
I need some help understanding something about my upper. Here are some details:
Boat: 1972 Silverline Comoro Tri-Hull
Engine: 1972 OMC 165 (Chevy inline 6 250)
Drive: 1972 OMC Electric Shift Stringer
Mechanic: 1970 model - "iffy" at his best
I've been dealing with an issue all summer long, and had the boat into the shop. Mechanic had it for six weeks (long story for another post - but I was traveling a lot, so it's a wash), and his final suggestion is that my upper is locked up.
I've posted on the original problem before, but for the moment I need to understand (before I go buy a new upper) if the drive is installed on the boat, and the engine is running (no grinding noises) - can the upper be locked up?
With the ball gears engaged, that upper is spinning correct? If it were "locked up" then the system would not even start - am I understanding that correctly?
