05blastsrt4
- Jun 14, 2011
- 43
Hello all,
Recently I got my boat running that I purchased, I drained changed the gear oil before ever taking it out and all looked fine. However after taking it out today I checked the oil and it was pretty milky. I do not see any leaks coming from the prop shaft nor any leaks out of the fill holes. The only thing I have had off that could possibly be letting water in is the electric shift solenoid cover on top of the lower unit:confused. I guess my question is, is it possible for water to get in the gear case from there??
edit:
Some more information, I did notice some gear oil coming out of the hole in the picture marked with the red dot, not sure if this helps or not.
edit:
