2000 Reinell Volvo/Penta 5.0 GL with SX outdrive.
Had the boat out for a day of tubing and cruising on Sunday. After being stopped for awhile I went to start the boat and absolutely nothing. Thought maybe the neutral lock out on the gear shift. I moved the gear shift forward then back to neutral and the boat started right up. At the end of the day we were about 100 yards off the ramp and turned off the boat to prepare it for taking out of the water. When we were ready to go, no start. Moved the gear shift into forward then back to neutral like earlier but still nothing. Tried this a number of times and still got no start. Was thinking if not the neutral lock out maybe an ignition switch problem. We got a tow back to the dock and while waiting at the dock I asked my wife to try and start it. Started right up. Now I wonder if it's a temperature thing as the motor was off for a good 45 minutes. Got home, put the muffs on and it started right up. I can easily replace the ignition switch but if that's not it which direction do I go to diagnose the problem?
Thanks
Thanks
