2-6volts(7Ah) rechargeable batteries in series...hooked in parallel,with a 12volt(120Ah) deep cycle battery.
First question.
Is there now 127 amp hours?
Next,when they need recharging,
can they stay in parallel(like they are)and be charged with one charger?
Could you use the 10/15amp charge rate because,it's 127 Ah's(10-15% rule,if there is one) or would you have to trickle charge them because of the 7 Ah batteries?
Lets say all batteries are new and not faulty,weak or with any other defects.
This isn't used for anything...just wondering.
I was going to ask about 8-1.5V batteries in series,hooked parallel with a big deep cycle.
I'm thinking 12 volts is 12 volts,am I wrong?
First question.
