I put in a new water pump about 3 weeks ago. It ran okay and the cylinders were cool to the touch after serveral minutes. I changed to a new prop from a 13x19 to 13 3/8 x 17 to get out of the hole better to pull grandkids. This may not have caused the problem.
First day out ran great. Second day suddenly lost 3/4 of the power and the flywheel was really hot. We eased back to the dock about a mile with the reduced power.
I took it out today and it ran ok for about 5 min then lost the power and the flywheel and cylinders were real hot.
How do I check the waterpump with water mufflers? I had a terrible time putting the lower unit back on and gave up and hired someone for $150. So I was hoping to check without removing the lower unit again. I am 67 and don't have the strengh to do it.
Can I disconnect the hose coming out of the cylinders and test?. There are two of them.
