Re: 1980 mercury 50 hp stalling
Do you find that you need to keep the fast idle up to keep it running? That typically means that you are running on one carb. If you don't run your motor out of fuel every time at the end of the day, you run the risk of sticking your float needles closed, the rubber tip in the needle swells and gets stuck in the seat. Sounds like a rebuild or a cleaning is in order, but not a bad job though and the kits are cheap. If you can squeeze your primer ball and it clears up, it's your fuel pump.
