hi all
i have a 83 70 hp evinrude the issue i have is this it starts and idles a little erratic but now bad but dies on throttle up unless the choke is bumped at the same time then runs fine. i have looked at the carbs ie pulled the screw plugs and jets cleaned with carb cleaner. on looking at diagrams they show a needle adjuster i can't find one on mine am i missing something? fuel is clean drained carbs nothing funky came out and floats seem to work properly. saw a few posts on timing as a maybe issue not sure how to do that correctly
thanks for any help
thanks for any help
