wright74012
- Jun 23, 2011
- 25
What is the proper prop size for a 25' pontoon with a 1999 Johnson 115hp?
A prop size and pitch is determined by the particular model and desired flying style, with the additional requirement that the maximum rpm should remain reasonable. I prefer to keep the maximum rpm in the 8500 to 9500 range, some people prefer a higher rpm but greater than 10,000 is probably not good. The rpm with a given prop will depend on the fuel used and brand of prop. A larger diameter or pitch can be used with fuel that has more nitro. Also some models fly better with bigger diameter and lower pitch , and other models are better with more pitch and less diameter; you have to experiment to determine what best suits you. Use the max rpm as a guide with values about 8500-9500 being satisfactory. Try these sizes as starting points, all are APC brand. If you use high-nitro content fuel you will probably need to use a larger size prop to limit the maximum rpm to about 9500. (Note: The Saito literature that accompanies most engines states a maximum rpm value that is quite a bit higher than my suggested 9500 rpm maximum value. I guess that the higher rpm numbers quoted by Saito are ?not too exceed values?, and not actual recommended operating rpm).
13 worked perfect. Thanks for all your help guys!
All my prop guy had was a 3 blade.
