Mercury 40hp fourstroke turns over but wont start
pbmlbt
I have a 2010 Sun Tracker with a Mercury 40 fourstroke efi motor. Usually when I turn the key to start the motor there is usually a beep noise and I can see my gauges move then I turn the key to start the motor. Now there is no beep and the gauges do not move however the starter does engage but it seems like there appears to be no ignition. The battery is has been replaced so it is not a battery problem.
