I was wondering on my 1985 85 hp force outboard on a 1985 bayliner is there any way to keep the motor supported when trailoring. I had a transom saver on my old trailor but this new trailor does not have a rear support beam and the nearest one is about half way up the trailor. My tilt and trim system has a slight leak down. And it gets worse with bounces, i saw the device that goes into the adjustment holes and the motor sits on that it would help keep the motor up but what about supporting the weight off the transom? Now that bar may be a little closer to the rear of the boat then half way but there is no way to put a transom saver to it. Unless there is something i am unaware of which is why i ask on here. I will try and get some pics up this evening of it. But from what i have seen it is the standard trailor for the bayliner capris.
