Mercruiser Leg Identification
mikealston2428
Hi there,
Please see attached.
Can you please tell me what Mercruiser leg this is ?
The decals are Alpha 1.
I had to replace the trim cylinders, they were Mercruiser MC1 parts.
The serial number plate has no numbers on it.
Your help is greatly appreciated
Thank you,
Mike.
thumpar
Re: Mercruiser Leg Identification
Hook on top and rounded cavitation plate look like a pre-alpha. Take the fin off before it breaks your cav plate off.
thumpar
Looks like your serial numbers are not there for the drive. That is about it. If they are not there then you will not find any for the drive.
Bt Doctur
look under this decal, numbers should be stamped .appears to be the MC1 drive.
