84 bayliner with 225D motor. Went to get gas filter, not the one by carb, but the one right by fuel pump. They sold me a kit that replaces that setup. They said i didnt need anything else, and it would bolt up. The old bolts don't even go thru the new housing , and even if they did, the holes don't line up. Do i have to find a place to mount this, and then plumb lines?
While taking everything apart, i noticed the metal gas line going from carb to fuel pump, had a hole in it. Where is the best place to look for these lines, or do i try and make them up?
