Hi,
I just purchased a boat with a 1997 Evinrude 115 outboard. There is fluid leaking from the double rams, and when activated at the switch, motor runs for up position, but doesn't run for down position. The relay activates, and 12v circuit closes when tested with multimeter.
Two questions... how to get the hydraulic motor running for down tilt, how to replace the leaky seals, and how to fill the fluid reservoir.
Thanks!
Tim.
Thanks!
Tim.
