Hi.. My 1986 johnson 110 hp will not go all the way into foward gear.. It goes into reverse without a problem.. When I put it into foward it sounds like its skipping or not steping into gear all the way.. When I moved the linkage adjusment it got better but when you try to to go faster it starts skipping again.. I feel like the shift rod is not moving all the way into position.. It skips so bad it moves the whole shift cable.. Any ideas whats wrong? Thanks Wayne
