Suzuki DT75 Exhaust Leak between lower unit and Midcase
bwflusa
I have a 1996 Suzuki DT75 leaking exhaust betweeen the Lower unit and Middle case. (1) is this abnormal (2) Will I do further damage by running it like this?
ADK_Boater
Re: Suzuki DT75 Exhaust Leak between lower unit and Midcase
Where is the leak coming from exactly? Where the two surfaces mate up? Make sure you are not getting any water in your gearcase as a consequence of the leak... depending on where it is. Post a pic of the exhaust leaking if you can.
