natemoore
Master Chief Petty Officer
- Jun 13, 2009
- 844
Here it is late July and we haven't been out on the boat once. A couple of months ago we were planning to go boating, but a rusty power steering line started squirting fluid at me. Other than that, it started on the first try and ran fine. In fact, the boat ran great all last year. We put over 20 hours on the boat with absolutely no problems.
So I broke out another $300 and replaced all the power steering lines.
I checked all the fluid levels, hooked up the muffs, and started it. It ran really, really roughly and was belching blue smoke. After a couple of minutes it steadied out. I checked oil pressure: good. I checked engine temp. Not even off the peg. I verified that water was coming out of the lower unit at a normal clip. Everything looked okay. I figured it was running roughly because the engine got rained on while I went to the store this morning.
Then I noticed that there was smoke coming from the rear of the exhaust elbow. It was scalding hot! The rubber bellows that connects the exhaust elbow to the exhaust pipe was also too hot to touch. The bellows adhesive was bubbling out from under the bellows.
I quickly shut it down. It only ran for about six minutes.
All the cooling system hoses were warm, but not hot.
I'm assuming that the blue smoke was the rubber exhaust flapper burning up.
The boat has been sitting up since May because I had to do two timing belt jobs and go camping a couple of times...oh yeah, and work.
Does anyone have any ideas?
