Munrofuryowner
- Jun 11, 2011
- 9
New to boating and just bought a old 70's runabout 650 mercury. I could not nail the year down exact but believe it to be 1971 thunderbolt has a red stripe.
Issue I have, hoping someone smarter than me knows, is that the engine will stop sometimes when running at either slow or fast speed, in about an hour the motor may stop 4 to 5 times.
When stops can usually restart but sometimes takes 5 min or so.
When stopped the fuel bulb has been both hard and soft.
Sometimes when re-start and get going the engine seems to be have less power but then rev up slightly to more power even without moving throttle
Any ideas on troubleshooting / what it could be / fixes to make sure it's not just bad gas - ie recommendations to add filter/other to fuel to ride water etc...
I know the sparks are good and the cyl compression checks fine, also replaced water pump and impeller so hope is not simply ethanol vapor lock.
Please help as I am new to outboards and am only learning this stuff from reading your threads
PS anyone got the original mercury service manual for 1971 650. 4 cyl? Will buy it if can find it
Andrew
Andrew
