DK in Chicago
- Sep 21, 2008
- 56
OK, so here's the situation. The boat I have (1988 18' Fish/Ski) sat out in the elements, summer and winter for 3 years before I got it. There are quite a few soft spots in the plywood, but now, the passenger pedestal chair has ripped its bolts through and fallen off.
I have read what needs to be done in regards to removing the floor, redoing the stringers, replacing the floor, etc. Sadly, there is no way I have the money to do that, but I would like to continue to use the boat for the next couple years until I can afford to do that, so here is my interim solution, and I would like your opinions on whether you thing it will be a suitable bridge to get me through the next couple years.
Home Depot sells .42 Hardi-backer board, similar to Durock, but smooth. It is typically used as the backer for walls around bathtubs, because of its resistance to water, and under tile floors as well. So I'm thinking, get enough to lay it out over the existing deck area, screw it down tight with the proper screws, seal the joints, and paint over it with a waterproof paint. Then glue down some new carpet over it and reinstall the pedestal chairs and ski locker door.
This boat is garage kept, and we're almost never out in the rain for any extended period of time if ever...
I figure it can't possibly be any worse than my current situation, and I don't see how it would worsen the situation for the repair in a few years. In the mean time I will have a solid floor, and can continue to enjoy my boat.... Thoughts?
