redeye1962
- Jul 6, 2008
- 319
I have a 94 90 hp rude that I have not taken out in a couple of years but did have the carbs rebuilt about 4 years ago. I ran the gas out last year and fogged the engine. I started it up last night after changing the gas filter and appeard to be good, this morning we were going to take it out to the lake and gas was leaking from a hole above the lower port carb. I am guessing this is an overflow hole if the bowl is full. I noticed when the engine was running there was gas flowing out of another hole (small pipe probably not the jet cuz those should be inside the carb area) while the other carbs were running dry. I tried to rev the engine up a bit to see if it would clear out but nothing. I did not want to rev too much while on a hose.
I am guessing something is stuck but not sure. I really wanted to take it out to the lake and run it hard hoping it would unstick but probably not a good choice leaking gas and all.
Any ideas? I really do not want to drop a ton of money in this thing again.
