sutor623
- May 23, 2011
- 4,089
I had to replace the supply line grommet at the powerhead on an 81 johnson 9.9 after I had a water pump failure. There is a small pinhole leak in the upper section of the copper input line. Is this supposed to be there? It looks like a pretty clean hole, but I want to make sure before I put the powerhead back together. I figured that it may be for a pressure relief of some sort. Thanks guys!!
