Hi,
I am posting my question here in hoping some one can help me confirm if the exhaust elbow gasket I have ordered for my Mercruiser is the right one.
In the pictures attached, the gasket on the right was removed from the motor when the exhaust elbow was removed. It appears to be made of stainless sheet metal with orange silicone sealant embedded on the mating surface. Of course, you can see from the picture, small section of the silicone sealant was peeled off during the removal process. As the result, I contacted my local shop and based on the serial number of my motor, they provided the gasket on the left. The replacement gasket is not made of stainless sheet metal. I?m a little concern if the paper like new gasket will be able to hold against water pump pressure.
My motor serial number L642848. It?s a Mercruiser 5.0L from year 2000.
Thanks!!
B
Thanks!!
B
