1985 wellcraft with 170 mercruiser
timmyt66
does anybody know what bolt pattern this engine has ie ford chevy i was thinking about changing engines and need to know what i can drop in without changing everything any help would be great thanks
Re: 1985 wellcraft with 170 mercruiser
The Easiest Swap would Probably be to a Merc. 4.3l.........<br />Your block is Merc.'s Own.........<br /><br />A V8 would require a ratio change in the outdrive......
