Re: 73 johnson 20hp carb settings
The low speed needle valve is 1 1/2 turns out from a lightly seated position for initial setting. Do a search for joe reeves carb setting as he explains this procedure perfectly. If your asking about the float setting, the float should be set level with the carb body when the carb is viewed upside down.
