I have been trying to find the source of fuel starvation for a couple of years. I have gone through the fuel system testing in the manual and determined there is no fuel blockage before or after the LP fuel pump which seems to be the issue. The pressure on the high side was inline and the FP regulator checked out. The pressure on the low side was at 1 psi. All tests seem to piont to the LP fuel pump being bad. I replaced the LP pump and it will work until it heats up. It gets very hot after a minute of use and then will not suck the fuel necessary. The engine will keep running because the HP pump is pulling the fuel into the reservoir. One thing I noticed on the electrical side is that the voltage to the pump is at 14.5 v. The manual asks if the voltage is at least 10.5 v to the pump but doesn't specify a maximum. Could this be causing the pump to run hot and fail?
