I removed the drive spline from one alpha one and put on my other, newer outdrive. The newer outdrive looks great inside, however, the ujoint when pushed out showed a kind of grittyness inside the needle bearing caps, not clean and shiny.
There seemed no slack or damage in any way, the ujoint is tight, and since I did not want to spend more money/time right now, I put the outdrive on the boat and would like to use it for the rest of the season before having to replace the entire ujoint with new.
Is it likely to hold up a while or do I need to bite the bullet on this.
Thanks
Thanks
