Initial startup is great but after the motor has been running for a while I can turn it off,
when I try to restart a few moments later I get a high idle (1800-2000 rpm) and then it
just cuts out, if I rev the motor past 2000 rpm's (MANUALLY BEFORE IT HAS A CHANCE
TO DIE) it will return to normal idle. If I just let it cut out, it then takes forever to get
it started again. Does anyone know what could be causing this problem???
