5.0 to 5.7
eo1scw
I am putting an automotive 5.7 in where a 5.0. What do I have to look forward to?
Re: 5.0 to 5.7
Ayuh,... Welcome Aboard,...
Yer lookin' at Alotta Work....
All the boltholes should be exactly where they belong though...
grendelsniper
Re: 5.0 to 5.7
you will gain more torq and power, it all depends on what automotive 5.7 you are looking at there are a million varitions from high torq to high horsepower, can you be more specific on the 5.7 in mind.
eo1scw
Re: 5.0 to 5.7
I don't know the specifics of the 5.7 except it is bored .40 over and it came out of a show truck. It has low miles and in good shape.
Doernuth
Re: 5.0 to 5.7
Changing all the electrical parts, fuel pump, carb, freeze plugs and things I haven't thought of yet.
littlebookworm
Re: 5.0 to 5.7
You need to change the head gaskets to brass or composite ones. Steel, automotive, ones will rust out quickly. All the freeze-out plugs need to be replaced. A truck cam should be OK. You need to use marine distributor, starter, water circulation pump, fuel pump, carb, and alternator. In some cases the intake manifold may need to be replaced, depending on the particulat engine and carb. The flame arrestor from the 5.0 should work. Valve covers might need replacement, again depending on the particular engine. The oil pan and dipstick should be OK. The harmonic balance should be OK. The crank pulley may need to be replaced. Take photos of the 5.0 before you pull it apart and out so you'll know where each bracket and hose goes. Use zip-lock bags to keep bolts and brackets separate. Label them. Get a manual for the Mercruiser engine of the series you're installing. It's not really that complicated. Good luck. Hy
eo1scw
Re: 5.0 to 5.7
Thank you Chief. I still have the 5.0 so I can put all the parts on the 5.7.
