homelite
- Aug 13, 2002
- 156
My above engine idles fine and runs fine. Just off idle, like 900 to 1200 rpm in gear or in neutral, i get a small idle up and down hunt. Timing is correct at 8deg with engine in proper mode for setting timing. No vac leaks. It is slight and a lot of people would never notice, but I do. Hit 1300 rpm and higher it's gone. It's like in that range the IAC doesn't quite know where it wants to be. There no trouble codes either. Just a normal code 12. Any help will be apprecated. Perhaps it can't be fixed.
